Introduzione
In order to reach the internal elements of the camera (lens, flashbulb, etc.), the following steps will tell you how to remove the front cover.
Parti
Nessuna parte richiesta.
Remove the memory stick from the camera.
  • Remove the memory stick from the camera.
  • Remove the batteries from the camera.
Aggiungi Commento
Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver. There is one screw hidden under the AV cover that also needs to be removed.
  • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
  • There is one screw hidden under the AV cover that also needs to be removed.
Aggiungi Commento
Pry the back cover from the left side of the camera. Remove the cover gently.
  • Pry the back cover from the left side of the camera. Remove the cover gently.
Aggiungi Commento
CAUTION! This is where energy for the flash is stored.  Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
  • CAUTION! This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
  • Newer cameras of descent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
Aggiungi Commento
Remove the tape on the right side of the LCD screen.
  • Remove the tape on the right side of the LCD screen.
  • Gently lift the LCD screen from its base.
  • Don't tug on the screen because it is still connected to the logic board.
Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
Mark Fraylick - Replica
Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
richardkujawa - Replica
I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
Lift the black latch connecting the LCD ribbon to the logic board.
  • Lift the black latch connecting the LCD ribbon to the logic board.
  • Gently pull the LCD ribbon out.
Aggiungi Commento
Pry back the front cover of the camera starting from the right side.
  • Pry back the front cover of the camera starting from the right side.
Aggiungi Commento
Conclusione
Andrea Govea
Membro da: 11/10/2010
357 Reputazione
2 Guide realizzate
Cal Poly, Team 9-23, Regan Fall 2010 Membro di Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,873
