Introduzione
This guide will walk you through the necessary steps to remove the eyepiece and LCD screen in the Nikon Coolpix E5700.
Parti
Nessuna parte richiesta.
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700. Open the battery door.
  • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
  • Open the battery door.
Aggiungi Commento
Pull the battery out of the E5700.
  • Pull the battery out of the E5700.
  • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
Aggiungi Commento
Turn to the bottom of the camera.
  • Turn to the bottom of the camera.
  • Remove the two Phillips screws located directly below the back monitor
Aggiungi Commento
Turn the camera to the side with the memory card slot and open the compartment for the CF card. Remove the top two Phillips screws closest to the back panel.
  • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
  • Remove the top two Phillips screws closest to the back panel.
Aggiungi Commento
Turn to the back of the camera.
  • Turn to the back of the camera.
  • Remove the top most Phillips screw on the back panel.
Aggiungi Commento
Turn to the last side of the back panel.
  • Turn to the last side of the back panel.
  • Remove the Phillips screw below the eyepiece.
  • Remove the Phillips screw located above the speaker.
Aggiungi Commento
Gently begin to remove the back panel. Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
Before pulling the panel. You MUST remove first de rubber bumper ( arrond the ocular piece ).
diego - Replica
Now gently unplug the two wires at the bottom of the panel. Now gently unplug the two wires at the bottom of the panel.
  • Now gently unplug the two wires at the bottom of the panel.
Aggiungi Commento
Finish pulling away the back panel.
  • Finish pulling away the back panel.
  • Turn the camera to its non-grip side.
  • Remove the Phillips screw located above the strap holder.
Aggiungi Commento
Open the CF card slot. Remove the Phillips screw near the top of the camera.
  • Open the CF card slot.
  • Remove the Phillips screw near the top of the camera.
Aggiungi Commento
Turn to the front of the camera.
  • Turn to the front of the camera.
  • Lift up the corner of the grip pad nearest to the flash bulb.
  • Remove the Phillips screw underneath the grip pad.
Aggiungi Commento
Lift up the flash bulb container. Remove the two Phillips screws located near the base of the section.
  • Lift up the flash bulb container.
  • Remove the two Phillips screws located near the base of the section.
Aggiungi Commento
Open the battery compartment. Remove the Phillips screw located at the bottom of the battery compartment.
  • Open the battery compartment.
  • Remove the Phillips screw located at the bottom of the battery compartment.
Aggiungi Commento
Begin to lift the top cover from the rest of the camera.
  • Begin to lift the top cover from the rest of the camera.
  • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
Aggiungi Commento
In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
Aggiungi Commento
Unplug the orange ribbon wire from the back of the camera. Unplug the two blue ribbon wires from the back of the camera.
  • Unplug the orange ribbon wire from the back of the camera.
  • Unplug the two blue ribbon wires from the back of the camera.
Aggiungi Commento
Remove the Phillips screws on both sides of the flash bulb mount. Remove the Phillips screws on both sides of the flash bulb mount.
  • Remove the Phillips screws on both sides of the flash bulb mount.
Aggiungi Commento
Lift the top panel up and pull the flash bulb housing away from the rest of the top panel. Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
  • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
Aggiungi Commento
Unplug the orange ribbon and the  other wires and finish carefully removing the top panel.
  • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
Aggiungi Commento
Remove the Phillips screws on either side of the viewfinder.
  • Remove the Phillips screws on either side of the viewfinder.
Aggiungi Commento
Unplug the red and black group of wires underneath the viewfinder.
  • Unplug the red and black group of wires underneath the viewfinder.
Aggiungi Commento
Slowly remove the viewfinder from the body of the camera. Unplug the orange ribbon wire from the body of the camera. Unplug the orange ribbon wire from the body of the camera.
  • Slowly remove the viewfinder from the body of the camera.
  • Unplug the orange ribbon wire from the body of the camera.
Aggiungi Commento
Remove the black tape from the back of the viewfinder. Remove the black tape from the back of the viewfinder.
  • Remove the black tape from the back of the viewfinder.
Aggiungi Commento
Remove the white panel from the back of the viewfinder. Remove the white panel from the back of the viewfinder.
  • Remove the white panel from the back of the viewfinder.
Aggiungi Commento
Remove the LCD screen from the viewfinder. Remove the LCD screen from the viewfinder. Remove the LCD screen from the viewfinder.
  • Remove the LCD screen from the viewfinder.
Aggiungi Commento
Conclusione
Kyle Sitton
Membro da: 17/04/2011
333 Reputazione
7 Guide realizzate
Cal Poly, Team 24-58, Amido Spring 2011 Membro di Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,113
