Introduzione
Use this guide to replace the LCD.
Parti
Nessuna parte richiesta.
Remove the four 3.0mm screws on the bottom of the camera.
  • Remove the four 3.0mm screws on the bottom of the camera.
Aggiungi Commento
Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Aggiungi Commento
Remove the two 3.0mm screws on the right side of the camera.
  • Remove the two 3.0mm screws on the right side of the camera.
Aggiungi Commento
Carefully open the back cover. Take care as there are connectors still attached.
  • Carefully open the back cover. Take care as there are connectors still attached.
Aggiungi Commento
Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Aggiungi Commento
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
  • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
  • The back cover will be disconnected from the camera
Aggiungi Commento
First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
  • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
  • Carefully flip the screen down to reveal the back of the screen
Aggiungi Commento
Disconnect the ribbon cable and gray connector with red and black wires.
  • Disconnect the ribbon cable and gray connector with red and black wires.
  • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
Aggiungi Commento
Conclusione
Kaky Payne
Membro da: 17/04/2012
58 Reputazione
5 Guide realizzate
Cal Poly, Team 12-38, Regan Spring 2012 Membro di Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 985
