Parti
Nessuna parte richiesta.
With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
Aggiungi Commento
Remove the chrome side cover from the body of the camera.
  • Remove the chrome side cover from the body of the camera.
Aggiungi Commento
Remove the four 3.2 mm screws on the bottom of the camera.
  • Remove the four 3.2 mm screws on the bottom of the camera.
Aggiungi Commento
Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
  • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Aggiungi Commento
Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
  • Gently separate the back cover from the body of the camera.
  • The back casing will still be connected to the circuit board by a ribbon
Aggiungi Commento
Use the tweezers to disconnect the ribbon from the circuit board.
  • Use the tweezers to disconnect the ribbon from the circuit board.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Aggiungi Commento
Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
  • Gently separate the front cover from the body of the camera.
  • The front casing will still be connected to the circuit board by a few wires
Aggiungi Commento
Remove the two 3.2 mm screws that hold the flash to the front cover.
  • Remove the two 3.2 mm screws that hold the flash to the front cover.
Aggiungi Commento
Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
  • Use the Spudger to remove the copper colored light bulb clip.
  • Remove the front cover entierly from the camera body.
Aggiungi Commento
From the top view of the camera, remove the one 5.8 mm screw. From the top view of the camera, remove the one 2.8 mm screw
  • From the top view of the camera, remove the one 5.8 mm screw.
  • From the top view of the camera, remove the one 2.8 mm screw
Aggiungi Commento
Remove the three 3.4 mm screws from the back side of the camera.
  • Remove the three 3.4 mm screws from the back side of the camera.
Aggiungi Commento
Remove the two 3.4 mm screws from the side of the camera.
  • Remove the two 3.4 mm screws from the side of the camera.
Aggiungi Commento
Separate the two metal body pieces from the rest of the camera.
  • Separate the two metal body pieces from the rest of the camera.
Aggiungi Commento
Gently remove the two ribbons connecting the lens to the mother board. Gently remove the two ribbons connecting the lens to the mother board.
  • Gently remove the two ribbons connecting the lens to the mother board.
Aggiungi Commento
Gently separate the camera lens from the mother board. Gently separate the camera lens from the mother board.
  • Gently separate the camera lens from the mother board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cuesta, Team 1-6, Zipperian Fall 2011 Membro di Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Membri
5 Guide realizzate
Any place where I could buy a new lens for the camera nowadays?
thesilver - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,874
