Introduzione
This guide is to be used to install the battery in the case that the battery dies or no longer functions properly. A Phillips screwdriver will be needed to complete this installation.
Strumenti
Nessun attrezzo richiesto.
Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
  • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
Aggiungi Commento
Press orange clip to eject battery (battery not shown).
  • Press orange clip to eject battery (battery not shown).
Aggiungi Commento
While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
  • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
Aggiungi Commento
Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
Aggiungi Commento
Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
  • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Patty Richeson
Membro da: 11/03/2013
75 Reputazione
4 Guide realizzate
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 360
