Introduzione
This guide is to be used to install the back cover in the event that it becomes damaged. A Phillips screwdriver will be needed to complete this installation.
Parti
Nessuna parte richiesta.
Remove wrist strap by unknotting the strap.
  • Remove wrist strap by unknotting the strap.
Aggiungi Commento
Open SD/Battery cover.
  • Open SD/Battery cover.
Aggiungi Commento
Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver. Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
  • Remove the four screws on the bottom of the camera using the Phillips-Head screwdriver.
Aggiungi Commento
Pull the silver side panels on each side. Pull the silver side panels on each side.
  • Pull the silver side panels on each side.
Aggiungi Commento
On the right side of the camera (that contains the wrist strap loop), use the  screwdriver to remove the two screws holding the backplate in place. Repeat this step for the left side.
  • On the right side of the camera (that contains the wrist strap loop), use the screwdriver to remove the two screws holding the backplate in place.
    • Repeat this step for the left side.
Aggiungi Commento
Pull the back silver faceplate to separate it from the rest of the camera. Pull the back silver faceplate to separate it from the rest of the camera.
  • Pull the back silver faceplate to separate it from the rest of the camera.
Aggiungi Commento
Conclusione
Patty Richeson
Membro da: 11/03/2013
75 Reputazione
4 Guide realizzate
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 360
