Introduzione
If your screen has stopped working or needs to be replaced for some other reason, follow this guide to remove your current screen.
Parti
Nessuna parte richiesta.
On the bottom right of the camera, locate the battery flap switch.
  • On the bottom right of the camera, locate the battery flap switch.
Aggiungi Commento
Move this switch to the right so the battery flap can flip open.
  • Move this switch to the right so the battery flap can flip open.
Aggiungi Commento
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Aggiungi Commento
Remove the three 3x3mm screws attached to the rear casing.
  • Remove the three 3x3mm screws attached to the rear casing.
Aggiungi Commento
The panel can be identified by the wifi logo on its upper half on the camera's side.
  • The panel can be identified by the wifi logo on its upper half on the camera's side.
  • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Aggiungi Commento
Pry the panel off from the bottom using your fingernail.
  • Pry the panel off from the bottom using your fingernail.
Aggiungi Commento
Remove the 3x2mm screw underneath the panel near the top of the camera.
  • Remove the 3x2mm screw underneath the panel near the top of the camera.
Aggiungi Commento
Remove the 4x3mm on the opposite side near the selector wheel. Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  • Remove the 4x3mm on the opposite side near the selector wheel.
  • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Aggiungi Commento
Pry the back panel away from the body of the camera, using the space you just opened up. Be careful not to damage the ribbon cable on the opposite end of the camera.
  • Pry the back panel away from the body of the camera, using the space you just opened up.
  • Be careful not to damage the ribbon cable on the opposite end of the camera.
  • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Aggiungi Commento
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables. The center connector is detached by flipping the black latch up and away from the center of the camera.
  • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
  • The center connector is detached by flipping the black latch up and away from the center of the camera.
  • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Aggiungi Commento
Pry the display from the rear casing using a spudger. Pry the display from the rear casing using a spudger.
  • Pry the display from the rear casing using a spudger.
Aggiungi Commento
Conclusione
Kevin Backers
Membro da: 26/01/2012
301 Reputazione
4 Guide realizzate
Cal Poly, Team 9-5, Regan Winter 2012 Membro di Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 372
