Introduzione
Use this guide to replace the SIM card.
Parti
Nessuna parte richiesta.
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Aggiungi Commento
Remove the rear panel from the Nexus S.
  • Remove the rear panel from the Nexus S.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Remove the battery from the Nexus S.
Aggiungi Commento
Use your thumb to slide the SIM card downwards from the SIM card slot. Remove the SIM card.
  • Use your thumb to slide the SIM card downwards from the SIM card slot.
  • Remove the SIM card.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,929
