Introduzione
This guide will help you replace the SIM Card board.
Parti
Nessuna parte richiesta.
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Aggiungi Commento
Remove the rear panel from the Nexus S.
  • Remove the rear panel from the Nexus S.
Aggiungi Commento
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Remove the battery from the Nexus S.
Aggiungi Commento
Use your thumb to slide the SIM card downwards from the SIM card slot. Remove the SIM card.
  • Use your thumb to slide the SIM card downwards from the SIM card slot.
  • Remove the SIM card.
Aggiungi Commento
Remove the six Phillips screws securing the rear inner frame to the inner case.
  • Remove the six Phillips screws securing the rear inner frame to the inner case.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
Aggiungi Commento
Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  • Insert the plastic opening tool to the right of the power button.
  • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
Aggiungi Commento
In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
Aggiungi Commento
Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
Aggiungi Commento
Lift and remove the rear inner frame from the Nexus S.
  • Lift and remove the rear inner frame from the Nexus S.
Aggiungi Commento
Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
Aggiungi Commento
Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard. Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard. Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
  • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
  • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
Aggiungi Commento
Lift and remove the SIM Card board out of the Nexus S.
  • Lift and remove the SIM Card board out of the Nexus S.
Aggiungi Commento
SIM Card board remains.
  • SIM Card board remains.
Aggiungi Commento
Conclusione
Altre 14 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 8,358
