Introduzione
The ball bearing ring allows the rotation of the top half of the Nexus Q. This allows the user to change the volume. The ring may have problems rotating smoothly due to particles and dust residue.
Squeeze and pull the cap to remove it from the Nexus Q.
  • Squeeze and pull the cap to remove it from the Nexus Q.
Aggiungi Commento
Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
Aggiungi Commento
Undo the ZIF connector by prying it with a spudger.
  • Undo the ZIF connector by prying it with a spudger.
Aggiungi Commento
Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
  • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
  • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
Aggiungi Commento
View the bottom half of the Nexus Q.
  • View the bottom half of the Nexus Q.
  • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
Aggiungi Commento
Remove the ball bearing ring.
  • Remove the ball bearing ring.
  • When placing a new ring in its place, make sure to orient it right or the top will not close.
Aggiungi Commento
Conclusione
Taewan Kim
Membro da: 31/01/2013
22 Reputazione
2 Guide realizzate
Cal Poly, Team 7-10, Maness Winter 2013 Membro di Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 412
