Parti
Nessuna parte richiesta.
Using the plastic opening tool, push the blade into the space between the case and lower cover. Turn the opening tool slightly, the lower cover will detach on that side.
  • Using the plastic opening tool, push the blade into the space between the case and lower cover.
  • Turn the opening tool slightly, the lower cover will detach on that side.
  • Repeat on other side of the seam.
  • The lower cover will slide off.
Aggiungi Commento
Remove the one T5 Torx screw
  • Remove the one T5 Torx screw
  • Remove the one #00 Philips screw
  • Lift up the end of the antenna housing and slide it outwards.
Aggiungi Commento
  • The vibrator is located on the back of the antenna housing.
  • Use the spudger to pry up on the axle of the motor.
Aggiungi Commento
Conclusione
Niklas Johnson
Membro da: 31/01/2012
1.063 Reputazione
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,507
