Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
  • Using two fingers, push up on the rear cover.
Aggiungi Commento
The rear cover slides up and off.
  • The rear cover slides up and off.
Aggiungi Commento
Using the plastic opening tools, pry the left bottom corner of the battery up.
  • Using the plastic opening tools, pry the left bottom corner of the battery up.
Aggiungi Commento
Pull the battery up and out.
  • Pull the battery up and out.
Aggiungi Commento
Remove the two Torx T5 screws.
  • Remove the two Torx T5 screws.
  • Remove the one Philips #00 screw.
#0 Phillis screw
skuhry - Replica
Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
  • Using the plastic opening tool, pry up the battery housing upwards.
  • Push pry tool down, undoing the plastic tab.
Aggiungi Commento
Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
  • Pry the upper left tab open on the battery housing.
Aggiungi Commento
Pry the top tab of the battery housing. Pry the top tab of the battery housing.
  • Pry the top tab of the battery housing.
Aggiungi Commento
Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
  • Pry the right side tab of the battery housing.
Aggiungi Commento
Pull up on the battery housing. Slide the battery housing out to remove it.
  • Pull up on the battery housing.
  • Slide the battery housing out to remove it.
Aggiungi Commento
Push up the speaker from the battery housing.
  • Push up the speaker from the battery housing.
Aggiungi Commento
Conclusione
Niklas Johnson
Membro da: 31/01/2012
1.063 Reputazione
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,373
