Introduzione
installing the front speaker
Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
  • Using two fingers, push up on the rear cover.
Aggiungi Commento
The rear cover slides up and off.
  • The rear cover slides up and off.
Aggiungi Commento
Using the plastic opening tools, pry the left bottom corner of the battery up.
  • Using the plastic opening tools, pry the left bottom corner of the battery up.
Aggiungi Commento
Pull the battery up and out.
  • Pull the battery up and out.
Aggiungi Commento
Remove the two Torx T5 screws.
  • Remove the two Torx T5 screws.
  • Remove the one Philips #00 screw.
#0 Phillis screw
skuhry - Replica
Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
  • Using the plastic opening tool, pry up the battery housing upwards.
  • Push pry tool down, undoing the plastic tab.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
  • Pry the upper left tab open on the battery housing.
Aggiungi Commento
Pry the top tab of the battery housing. Pry the top tab of the battery housing.
  • Pry the top tab of the battery housing.
Aggiungi Commento
Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
  • Pry the right side tab of the battery housing.
Aggiungi Commento
Pull up on the battery housing. Slide the battery housing out to remove it.
  • Pull up on the battery housing.
  • Slide the battery housing out to remove it.
Aggiungi Commento
Insert the spudger under the connector. Push the spudger up and twist to release the connector.
  • Insert the spudger under the connector.
  • Push the spudger up and twist to release the connector.
  • Repeat for the next connector.
Aggiungi Commento
Push on the USB port to expose the black connector. Use the spudger to pry the connector upwards. Use the spudger to pry the connector upwards.
  • Push on the USB port to expose the black connector.
  • Use the spudger to pry the connector upwards.
The philips screw holding down the logic board (at the lower right corner in the picture) has to be removed before the board can be pushed back.
Mark - Replica
Place the spugder under the antenna connector. Pry connector up vertically.
  • Place the spugder under the antenna connector.
  • Pry connector up vertically.
Aggiungi Commento
Insert the spudger into tab above the camera. Slide upwards until the board detaches from the case. Slide upwards until the board detaches from the case.
  • Insert the spudger into tab above the camera.
  • Slide upwards until the board detaches from the case.
A philips screw holding down the upper logic board (in the lower left corner of the picture) must be remobed before the board can be detached.
Mark - Replica
Press the pointed tip of the spudger into the space below the button assembly.
  • Press the pointed tip of the spudger into the space below the button assembly.
  • Wiggle the spudger tip towards the outside of the button.
  • The button assembly is under some tension and may fly off.
Aggiungi Commento
Push the pointed tip of the spudger into the base of the side button board.
  • Push the pointed tip of the spudger into the base of the side button board.
  • Lift up, the board will disconnect from the case.
Aggiungi Commento
Push on the lower motherboard until it slides under the case support. The motherboard assembly comes out as a single piece. Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  • Push on the lower motherboard until it slides under the case support.
  • The motherboard assembly comes out as a single piece.
  • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
Be carefull not to tear the home button cable that is in the top right corner!!
zack - Replica
Using the spudger, pop up the end of the speaker.
  • Using the spudger, pop up the end of the speaker.
Aggiungi Commento
Conclusione
Niklas Johnson
Membro da: 31/01/2012
1.063 Reputazione
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,198
