Salta al contenuto principale
Nexus 9 Front Facing Camera Replacement
Cosa ti serve
  1. Nexus 9 Front Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 3 Nexus 9 Front Facing Camera Replacement, Rear Case: passo 1, immagine 2 di 3 Nexus 9 Front Facing Camera Replacement, Rear Case: passo 1, immagine 3 di 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: passo 2, immagine 1 di 1
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Conclusione
Geoff Wacker
Membro da: 09/30/13
89.996 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 761
