Salta al contenuto principale
Nexus 9 Antenna Board Replacement
Cosa ti serve
  1. Nexus 9 Antenna Board Replacement, Rear Case: passo 1, immagine 1 di 3 Nexus 9 Antenna Board Replacement, Rear Case: passo 1, immagine 2 di 3 Nexus 9 Antenna Board Replacement, Rear Case: passo 1, immagine 3 di 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: passo 2, immagine 1 di 2 Nexus 9 Antenna Board Replacement, Antenna Board: passo 2, immagine 2 di 2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: passo 3, immagine 1 di 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: passo 4, immagine 1 di 1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
Conclusione
Geoff Wacker
Membro da: 09/30/13
89.996 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,399
