Salta al contenuto principale
Nexus 4 Power and Volume Button Replacement
Cosa ti serve
  1. Nexus 4 Power and Volume Button Replacement, Back Cover: passo 1, immagine 1 di 2 Nexus 4 Power and Volume Button Replacement, Back Cover: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    SIM Card Eject Tool
    $2.99
    Compra
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Power and Volume Button Replacement: passo 2, immagine 1 di 1
    T5 Torx Screwdriver
    $5.49
    Compra
  3. Nexus 4 Power and Volume Button Replacement: passo 3, immagine 1 di 3 Nexus 4 Power and Volume Button Replacement: passo 3, immagine 2 di 3 Nexus 4 Power and Volume Button Replacement: passo 3, immagine 3 di 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Power and Volume Button Replacement, Power and Volume Button: passo 4, immagine 1 di 2 Nexus 4 Power and Volume Button Replacement, Power and Volume Button: passo 4, immagine 2 di 2
    • Holding the back case, gently push the power button in towards the center of the phone using a spudger.
  5. Nexus 4 Power and Volume Button Replacement: passo 5, immagine 1 di 3 Nexus 4 Power and Volume Button Replacement: passo 5, immagine 2 di 3 Nexus 4 Power and Volume Button Replacement: passo 5, immagine 3 di 3
    • To remove the volume button, push the button in towards the center of the phone using a spudger.
Conclusione
Altre 16 persone hanno completato questa guida.
Kaitlyn Jones
Membro da: 01/27/13
4.952 Reputazione
8 Guide realizzate
Cal Poly, Team 3-32, Amido Winter 2013 Membro di Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 29,781
