Parti
Nessuna parte richiesta.
Turn the device over so it is upside-down.
  • Turn the device over so it is upside-down.
Aggiungi Commento
Unscrew the 4 screws closest to the screen.
  • Unscrew the 4 screws closest to the screen.
Aggiungi Commento
Flip over the device so it is right side up.
  • Flip over the device so it is right side up.
Aggiungi Commento
Unscrew the 2 screws on the top of the device, next to the docking plug.
  • Unscrew the 2 screws on the top of the device, next to the docking plug.
Aggiungi Commento
Take off top piece by using slight force and pulling off.
  • Take off top piece by using slight force and pulling off.
Aggiungi Commento
Unscrew the button board with smaller screwdriver.
  • Unscrew the button board with smaller screwdriver.
Aggiungi Commento
Lift off the button board.
  • Lift off the button board.
Aggiungi Commento
Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
Aggiungi Commento
Lift the screen vertically straight up.
  • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
Aggiungi Commento
Flip the screen and the logic board over to the right side.
  • Flip the screen and the logic board over to the right side.
Aggiungi Commento
Pull out the white plug that goes from the speakers to the logic board.
  • Pull out the white plug that goes from the speakers to the logic board.
  • Then plug back in making sure it is completely connected.
Aggiungi Commento
Conclusione
Michelle Read
Membro da: 26/09/2012
1 Reputazione
1 Guida realizzata
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 299
