Salta al contenuto principale
Nextplay NP109CR Disassembly
Cosa ti serve
  1. Nextplay NP109CR Disassembly, Nextplay NP109CR Disassembly: passo 1, immagine 1 di 1
    • Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
  2. Nextplay NP109CR Disassembly: passo 2, immagine 1 di 1
    • Remove the lid from the device.
  3. Nextplay NP109CR Disassembly: passo 3, immagine 1 di 1
    • Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
  4. Nextplay NP109CR Disassembly: passo 4, immagine 1 di 2 Nextplay NP109CR Disassembly: passo 4, immagine 2 di 2
    • Remove the pink button sheet from the device by pulling out each button.
Conclusione
Reverse these steps to reassemble the device.
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 330
