Introduzione
The button sheet on the Nextplay NP109CR is sometimes placed incorrectly on the device. This prevents the buttons from working correctly. This guide will fix and place the buttons correctly on to the sheet. Use this guide to disassemble the device to reach the buttons. Follow the step by step instructions to re-position the buttons.
Strumenti
Parti
Nessuna parte richiesta.
Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
  • Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
Aggiungi Commento
Remove the lid from the device.
  • Remove the lid from the device.
Aggiungi Commento
Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
  • Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
Aggiungi Commento
Remove the pink button sheet from the device by pulling out each button. Remove the pink button sheet from the device by pulling out each button.
  • Remove the pink button sheet from the device by pulling out each button.
Aggiungi Commento
Conclusione
Reverse these steps to reassemble the device.
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 226
