Salta al contenuto principale
Netgear WGR614v9 Motherboard Replacement
Cosa ti serve
  1. Netgear WGR614v9 Motherboard Replacement, Lower Case: passo 1, immagine 1 di 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Motherboard Replacement: passo 2, immagine 1 di 2 Netgear WGR614v9 Motherboard Replacement: passo 2, immagine 2 di 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Motherboard Replacement: passo 3, immagine 1 di 2 Netgear WGR614v9 Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Motherboard Replacement: passo 6, immagine 1 di 2 Netgear WGR614v9 Motherboard Replacement: passo 6, immagine 2 di 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
Conclusione
Ryan Murphy
Membro da: 10/03/11
488 Reputazione
4 Guide realizzate
Cal Poly, Team 21-24, Maness Fall 2011 Membro di Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,220
