Introduzione
By removing the case you will be able to install a capacitor or an antenna.
Parti
Nessuna parte richiesta.
Rotate the device so that the bottom is facing up.
  • Rotate the device so that the bottom is facing up.
Aggiungi Commento
Lift up all four rubber pads on the bottom of the router with the plastic opening tool. Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
  • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
Aggiungi Commento
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router. Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Aggiungi Commento
Lift the bottom casing straight up from the router.
  • Lift the bottom casing straight up from the router.
Aggiungi Commento
Conclusione
Ryan Murphy
Membro da: 03/10/2011
482 Reputazione
5 Guide realizzate
Cal Poly, Team 21-24, Maness Fall 2011 Membro di Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,178
