Introduzione
Replacing the battery on your Nest couldn't be easier. Removing 4 screws gets you into the Nest's display and the battery comes right out. The only tools required are tweezers and a #0 Phillips screwdriver.
Parti
Nessuna parte richiesta.
Grasp the display's metal outer ring with your fingers and pull directly away from the wall. Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
Aggiungi Commento
Turn the display over.
  • Turn the display over.
  • Remove the four 6 mm screws from the back of the display using a #0 Phillips screwdriver.
Aggiungi Commento
Pinch the grey 20-pin connector with your fingers and pull directly away from the display. Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  • Pinch the grey 20-pin connector with your fingers and pull directly away from the display.
  • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
Aggiungi Commento
Locate the blue pull tab at the end of the ribbon which says, "1. Pull". Grasp the tab with your fingers and pull directly away from the motherboard. Grasp the tab with your fingers and pull directly away from the motherboard.
  • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
  • Grasp the tab with your fingers and pull directly away from the motherboard.
How do you reattached the ribbon back to the motherboard ??
alexehler - Replica
Locate the blue tab which says, "2. Pull". Use tweezers to pull the battery up and away from the display.
  • Locate the blue tab which says, "2. Pull".
  • Use tweezers to pull the battery up and away from the display.
  • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
Aggiungi Commento
Locate the blue tab which says "3 unplug". Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  • Locate the blue tab which says "3 unplug".
  • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
Aggiungi Commento
Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display. Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display. Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
Where do you buy the battery?
Robert - Replica
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team 11-5, Blackwell Fall 2014 Membro di USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Membri
6 Guide realizzate
It should be noted that doing this will void the warranty on your device. If you are having issues with the display battery you should call the tech support line and they will help you. Doing this risk damaging the device and making it to where they will not replace it if it is still under warranty.
Bob bobbado - Replica
ON MY NEST WHEN YOU "pull 2"...IT WAS GLUED TO THE METAL TOP OP THE MOTHERBOARD UNDERNEATH...SO IF THIS IS THE CASE BE VERY CAREFUL AS YOU DISLODGE THE BATTERY ....ALSO THE PLUG FOR THE BATTERY WAS TAPED DOWN WITH AMBER COLORED TAPE WHICH I HAD TO REMOVE BEFORE I WAS ABLE TO UNPLUG THE BATTERY...I REPLACED THE TAPE WITH SOME SCOTCH TAPE AFTER REINSTALLING THE BATTERY...ALL IN ALL...GOO INSTRUCTIONS...A FIVE MINUTE FIX !!!
Andrew Jordan - Replica
I also am having a time finding the replacement battery
Brian wilson -
I am having trouble locating a replacement battery. Any idea where to look?
Ron Temaat - Replica
As of 12/28/17 this website has replacement batteries for Gen1 and Gen2 Nests:
http://www.batteryclerk.com/products/nes...
Ron Saritzky - Replica
As of 12/28/17 this website has replacement batteries for $12 plus shipping:
Here’s a direct link to the Gen1 battery page which has a link to the Gen2 battery page
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 31
Ultimi 7 Giorni: 185
Ultimi 30 Giorni: 821
Tutti i Tempi: 33,989
