Introduzione
A damaged or missing trigger spring can prevent your rifle from firing. This guide shows you how to access and replace the small trigger spring in the Nerf N-Strike Elite Alpha Trooper CS-12.
There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
  • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
  • Be sure that the rifle is discharged and unloaded before starting disassembly.
Aggiungi Commento
Looking at the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle. Pull off the orange cap. Pull off the orange cap.
  • Looking at the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
  • Pull off the orange cap.
Aggiungi Commento
With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together. Remove the three 10 mm phillips screws from the bottom of the slide mechanism. Remove the two halves of the slide mechanism.
  • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
  • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
  • Remove the two halves of the slide mechanism.
  • Make sure to keep track of which screws correspond to which holes.
Aggiungi Commento
Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle. Remove the two 5mm phillips screws from the main body.
  • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
  • Remove the two 5mm phillips screws from the main body.
  • Remove the two 8 mm phillips screws from the main body.
  • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
Aggiungi Commento
Pull the two halves of the rifle apart. Be careful of the spring at the rear end of the rifle. It may come flying out. If you have difficulty pulling the two halves apart, use a spudger gently pry the edges of the body apart.
  • Pull the two halves of the rifle apart.
  • Be careful of the spring at the rear end of the rifle. It may come flying out.
  • If you have difficulty pulling the two halves apart, use a spudger gently pry the edges of the body apart.
  • Also be careful of small parts when opening the gun, they may be easy to lose.
  • Remove the access gate and barrel cover.
Aggiungi Commento
Remove the single 8mm phillips screw holding the trigger mechanism is place. Remove the trigger mechanism. Remove the small spring from the rear of the mechanism and replace it with a new spring.
  • Remove the single 8mm phillips screw holding the trigger mechanism is place.
  • Remove the trigger mechanism.
  • Remove the small spring from the rear of the mechanism and replace it with a new spring.
Aggiungi Commento
Conclusione
Henrique Chan
Membro da: 24/01/2014
267 Reputazione
2 Guide realizzate
Cal Poly, Team 10-35, Maness Winter 2014 Membro di Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 51
Tutti i Tempi: 2,909
