Salta al contenuto principale
Neato XV-21 Battery Replacement/Removal
Cosa ti serve
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: passo 1, immagine 1 di 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: passo 2, immagine 1 di 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: passo 3, immagine 1 di 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: passo 4, immagine 1 di 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,130
