Introduzione
This guide will instruct how to install the power supply.
Turn the device so that the bottom is facing up.
  • Turn the device so that the bottom is facing up.
Aggiungi Commento
Use the plastic opening tool to carefully lift the rubber stops in each corner. Do not completely remove the rubber stops, because they are difficult to replace. Do not completely remove the rubber stops, because they are difficult to replace.
  • Use the plastic opening tool to carefully lift the rubber stops in each corner.
  • Do not completely remove the rubber stops, because they are difficult to replace.
Aggiungi Commento
Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device. Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
Aggiungi Commento
Lift the lower case straight up from the rest of the router. Lift the lower case straight up from the rest of the router.
  • Lift the lower case straight up from the rest of the router.
Aggiungi Commento
Remove the clear plastic casing by lifting it straight up from the router. Remove the clear plastic casing by lifting it straight up from the router.
  • Remove the clear plastic casing by lifting it straight up from the router.
Aggiungi Commento
Separate the motherboard from the top shell by lifting it straight up from the router. Separate the motherboard from the top shell by lifting it straight up from the router.
  • Separate the motherboard from the top shell by lifting it straight up from the router.
Aggiungi Commento
Turn the motherboard, so that the top is facing upwards.
  • Turn the motherboard, so that the top is facing upwards.
  • Place the motherboard on a clean flat surface.
Aggiungi Commento
Remove the yellow tape that holds the wire. Make sure that you set the tape aside on a clean surface, so that it can be reused.
  • Remove the yellow tape that holds the wire.
  • Make sure that you set the tape aside on a clean surface, so that it can be reused.
Aggiungi Commento
Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard. The wire should now be completely separate from the motherboard. The wire should now be completely separate from the motherboard.
  • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
  • The wire should now be completely separate from the motherboard.
Aggiungi Commento
Extend the antenna away from the device, so that it becomes straight.
  • Extend the antenna away from the device, so that it becomes straight.
Aggiungi Commento
Find the clips that hold the antenna onto the router. Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole. The antenna may take considerable force to remove.
  • Find the clips that hold the antenna onto the router.
  • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
  • The antenna may take considerable force to remove.
Aggiungi Commento
Completely separate the antenna and wire from the rest of the device.
  • Completely separate the antenna and wire from the rest of the device.
Aggiungi Commento
Unscrew the two 5 mm  Phillips Head screws located at the front corners of the motherboard.
  • Unscrew the two 5 mm Phillips Head screws located at the front corners of the motherboard.
Aggiungi Commento
Take off the metal frame. Take off the metal frame.
  • Take off the metal frame.
Aggiungi Commento
Turn over the motherboard, so that the bottom is facing up.
  • Turn over the motherboard, so that the bottom is facing up.
Aggiungi Commento
Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes. Desolder the three connections between the reset button and the motherboard
  • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
  • Desolder the three connections between the reset button and the motherboard
  • For proper soldering and desoldering techniques, refer here.
  • Pull the power source from the other side of the mother board once the solder is liquid.
Aggiungi Commento
Conclusione
Nicole Slagle
Membro da: 25/01/2013
77 Reputazione
2 Guide realizzate
Cal Poly, Team 3-31, Amido Winter 2013 Membro di Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,395
