Introduzione
If pulling the trigger of your Nerf Nite Finder doesn't cause it to fire, the trigger might need to be replaced. This guide shows how to do so.
==CAUTION==
Be aware of springs under compression. Take care so these small parts do not fly off the blaster and get lost.
Parti
Nessuna parte richiesta.
Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
  • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
  • Remove the battery door and take the batteries out.
Aggiungi Commento
Set the blaster on its side with the screws facing up (the blaster will be placed on its left side).  Remove all 14 phillips head, 8.2 mm screws and set them aside. Lift the side of the blaster off exposing its internal parts. Lift the side of the blaster off exposing its internal parts.
  • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
  • Lift the side of the blaster off exposing its internal parts.
Aggiungi Commento
Remove the phillips head, 10.2 mm screw holding the trigger in place. Remove the phillips head, 10.2 mm screw holding the trigger in place.
  • Remove the phillips head, 10.2 mm screw holding the trigger in place.
Aggiungi Commento
Remove the trigger by pulling the piece straight up.
  • Remove the trigger by pulling the piece straight up.
  • Caution: Do not let the spring fly off the spring
Aggiungi Commento
Conclusione
Kyle Schober
Membro da: 24/02/2014
580 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 953
