Introduzione
If you have a broken pedal or desire pedal clips this guide will assist you in removing and replacing your pedals.
Strumenti
Parti
Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
Aggiungi Commento
Locate the 15mm pedal nut, and position the crank arms for maximum leverage. Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm. A considerable amount of force may be required to break pedal nut free.
  • Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
  • Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
  • A considerable amount of force may be required to break pedal nut free.
clockwise or counter-clockwise to remove pedal?
Andrew J Davey - Replica
Conclusione
To install new pedal, follow these instructions in reverse order.
Samantha Rawlins
Membro da: 21/01/2014
386 Reputazione
3 Guide realizzate
Cal Poly, Team 1-40, Maness Winter 2014 Membro di Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,077
