Introduzione
The bottom cover must be removed prior to replacing or repairing any internal parts of the Mr. Coffee TF6 (hot plate, power cord, and water tubes). In the event that the bottom cover breaks or must be replaced, a replacement cover must by obtained from the manufacturer.
Parti
Nessuna parte richiesta.
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Aggiungi Commento
Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
Aggiungi Commento
Gently lift the bottom cover, detaching it from the main body of the TF6.
  • Gently lift the bottom cover, detaching it from the main body of the TF6.
Aggiungi Commento
Conclusione
Johnny Romeka
Membro da: 24/01/2014
201 Reputazione
2 Guide realizzate
Cal Poly, Team 13-18, Regan Winter 2014 Membro di Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 342
