Salta al contenuto principale
Mr. Coffee DW13 Base Removal
Cosa ti serve
  1. Mr. Coffee DW13 Base Removal, Base: passo 1, immagine 1 di 2 Mr. Coffee DW13 Base Removal, Base: passo 1, immagine 2 di 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Base Removal: passo 2, immagine 1 di 2 Mr. Coffee DW13 Base Removal: passo 2, immagine 2 di 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Base Removal: passo 3, immagine 1 di 1
    • Gently lift the base cover to expose the inside of the coffee machine.
Conclusione
Tess Bradley
Membro da: 01/26/14
373 Reputazione
3 Guide realizzate
Cal Poly, Team 10-31, Maness Winter 2014 Membro di Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,108
