Introduzione
Today we are going to repair the speaker system in the phone. This may be due to simple wire disconnections and may require soldering or a replacement of the system.
Parti
Nessuna parte richiesta.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Aggiungi Commento
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Aggiungi Commento
Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
  • Unscrew the antenna in a counter-clockwise fashion.
  • Remove the aluminum cover.
Aggiungi Commento
Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
  • Unscrew the 3 screws shown.
  • Lift up the right part of the Nextel logo and unscrew the screw underneath.
Aggiungi Commento
DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
  • DO NOT force the cover off as it could damage the ribbon cable!
  • Gently lift the back cover off.
Aggiungi Commento
Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
  • Carefully pry off the connection between the headphone jack and logic board.
Aggiungi Commento
Use the prying tools to wedge out the circular part of the speaker system. Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers. Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
  • Use the prying tools to wedge out the circular part of the speaker system.
  • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
Aggiungi Commento
Conclusione
Jorge
Membro da: 14/04/2010
4 Reputazione
4 Guide realizzate
Cal Poly, Team 29-61, Johann Spring 2010 Membro di Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,122
