Salta al contenuto principale
Motorola i850 SIM Card Replacement
  1. Motorola i850 SIM Card Replacement, Disassembling Motorola i850 Back Cover: passo 1, immagine 1 di 1
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Motorola i850 SIM Card Replacement: passo 2, immagine 1 di 2 Motorola i850 SIM Card Replacement: passo 2, immagine 2 di 2
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Motorola i850 SIM Card Replacement, Battery: passo 3, immagine 1 di 1
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Motorola i850 SIM Card Replacement: passo 4, immagine 1 di 2 Motorola i850 SIM Card Replacement: passo 4, immagine 2 di 2
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Motorola i850 SIM Card Replacement, SIM Card: passo 5, immagine 1 di 1
    • Place thumb on SIM Card door latch.
  6. Motorola i850 SIM Card Replacement: passo 6, immagine 1 di 1
    • Slide the SIM Card door latch away from the SIM Card. The door should pop open. If it does not pop open, use a fingernail to open it.
  7. Motorola i850 SIM Card Replacement: passo 7, immagine 1 di 1
    • Lift the SIM Card with your thumb and forefinger to complete the removal of the SIM card!
Conclusione
Cal Poly, Team 34-56, Forte Spring 2010 Membro di Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,577
