Introduzione
Replacement of malfunctioning LCD screen.
Open the flip cover of the phone with the LCD screen facing towards you.
  • Open the flip cover of the phone with the LCD screen facing towards you.
Aggiungi Commento
Use a Razor Blade to remove the screw covers. Razor Blade is very sharp. Use caution.
  • Use a Razor Blade to remove the screw covers.
  • Razor Blade is very sharp. Use caution.
Aggiungi Commento
Unscrew the screws using a Phillips #00 Screwdriver.
  • Unscrew the screws using a Phillips #00 Screwdriver.
Aggiungi Commento
Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
Aggiungi Commento
Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
Aggiungi Commento
Partially close the flip cover of the phone in order to take off the outer case.
  • Partially close the flip cover of the phone in order to take off the outer case.
Aggiungi Commento
Completely remove the outer casing from the phone.
  • Completely remove the outer casing from the phone.
Aggiungi Commento
Place your thumb underneath the protective metal covering to remove it from the phone. Place your thumb underneath the protective metal covering to remove it from the phone.
  • Place your thumb underneath the protective metal covering to remove it from the phone.
Aggiungi Commento
Gently detach the black microchip from the phone with a Tweezer.
  • Gently detach the black microchip from the phone with a Tweezer.
Aggiungi Commento
Prop out the LCD board from the phone using your fingertips.
  • Prop out the LCD board from the phone using your fingertips.
Aggiungi Commento
Remove the LCD board from the phone by grabbing the bottom side of the LCD board. Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Aggiungi Commento
Firmly detach the gold strip using a Tweezer.
  • Firmly detach the gold strip using a Tweezer.
Aggiungi Commento
Prop out the LCD screen using a Small Flathead Screwdriver.
  • Prop out the LCD screen using a Small Flathead Screwdriver.
Aggiungi Commento
Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board.
  • Remove the LCD screen from the LCD board.
Aggiungi Commento
Conclusione
Andrew Aw
Membro da: 08/04/2010
1 Reputazione
2 Guide realizzate
Cal Poly, Team 34-56, Forte Spring 2010 Membro di Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,034
