Salta al contenuto principale
Motorola i710 LCD Screen Replacement
Cosa ti serve
  1. Motorola i710 LCD Screen Replacement, Battery Cover: passo 1, immagine 1 di 2 Motorola i710 LCD Screen Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Replacement, Battery: passo 2, immagine 1 di 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: passo 3, immagine 1 di 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: passo 3, immagine 2 di 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: passo 3, immagine 3 di 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Replacement: passo 4, immagine 1 di 2 Motorola i710 LCD Screen Replacement: passo 4, immagine 2 di 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Replacement: passo 5, immagine 1 di 3 Motorola i710 LCD Screen Replacement: passo 5, immagine 2 di 3 Motorola i710 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
  6. Motorola i710 LCD Screen Replacement, LCD Screen: passo 6, immagine 1 di 3 Motorola i710 LCD Screen Replacement, LCD Screen: passo 6, immagine 2 di 3 Motorola i710 LCD Screen Replacement, LCD Screen: passo 6, immagine 3 di 3
    • Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
    • The LCD Scren will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
Conclusione
Carson Meena
Membro da: 10/22/12
16 Reputazione
5 Guide realizzate
Clemson, Team 14-2, Benson Fall 2012 Membro di Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 400
