Salta al contenuto principale
Motorola i560 Keypad Replacement
Cosa ti serve
  1. Motorola i560 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Keypad Replacement: passo 2, immagine 1 di 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Keypad Replacement, Motherboard: passo 3, immagine 1 di 1
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Keypad Replacement: passo 4, immagine 1 di 1
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Keypad Replacement: passo 5, immagine 1 di 2 Motorola i560 Keypad Replacement: passo 5, immagine 2 di 2
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Keypad Replacement: passo 6, immagine 1 di 2 Motorola i560 Keypad Replacement: passo 6, immagine 2 di 2
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Keypad Replacement: passo 7, immagine 1 di 2 Motorola i560 Keypad Replacement: passo 7, immagine 2 di 2
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Keypad Replacement: passo 8, immagine 1 di 1
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
  9. Motorola i560 Keypad Replacement, Keypad: passo 9, immagine 1 di 1
    • Push lightly from the front of the keypad to remove it.
Conclusione
Haley S
Membro da: 03/11/13
10 Reputazione
4 Guide realizzate
Clemson, Team 13-6, Benson Spring 2013 Membro di Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 158
