Introduzione
The keypad protects the phone's interior while enabling the user to input commands into the phone.
Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
  • Place the phone on a flat surface with the front facing down.
  • Insert your finger under the gray plastic cover at the bottom end of the phone.
  • Lift the cover off the phone.
Aggiungi Commento
Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
  • Place your thumb in the notch in the lower left corner of the battery compartment.
  • Lift the battery up and away from the phone.
  • Remove the battery.
Aggiungi Commento
Locate the metal slider that holds the SIM card in place. Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  • Locate the metal slider that holds the SIM card in place.
  • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
Aggiungi Commento
Lift the metal flap to gain access to the bottom of the SIM card. Remove the SIM card by sliding it out parallel to the bottom of the flap. Remove the SIM card by sliding it out parallel to the bottom of the flap.
  • Lift the metal flap to gain access to the bottom of the SIM card.
  • Remove the SIM card by sliding it out parallel to the bottom of the flap.
Aggiungi Commento
Extend the antenna.
  • Extend the antenna.
Aggiungi Commento
Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
  • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
  • If the antenna is not fully extended, the top left screw will not be accessible.
Aggiungi Commento
Gently lift off the back half of the phone and set to the side. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  • Gently lift off the back half of the phone and set to the side.
  • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Aggiungi Commento
Gently lift the end of the circuit board farthest from the phone hinge. The circuit board is permanently connected to the phone casing at the end nearest to the hinge. Grasp the keypad at the bottom of the phone, raise it, and pull it away.
  • Gently lift the end of the circuit board farthest from the phone hinge.
  • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
  • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
Aggiungi Commento
Conclusione
Garrison Stevens
Membro da: 22/10/2012
1 Reputazione
11 Guide realizzate
Clemson, Team 15-2, Benson Fall 2012 Membro di Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 364
