Introduzione
Throughout the use of the cell phone it is common for the keypad to become worn. This guide provides details on how to replace the rubber cover that acts as the phone's keypad interface. Performing this replacement requires little technical knowledge other than how to follow a series of instructions.
Be sure phone is powered off before removing the battery. Push the tab located at the bottom of the battery towards the top of the phone. Lift the battery away from the phone.
  • Be sure phone is powered off before removing the battery.
  • Push the tab located at the bottom of the battery towards the top of the phone.
  • Lift the battery away from the phone.
Aggiungi Commento
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed. Pull the antenna straight out of the phone. Pull the antenna straight out of the phone.
  • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
  • Pull the antenna straight out of the phone.
Aggiungi Commento
Pry off the bottom piece using the spudger. There are notches on the edge of this piece that can be used to aid prying. There are notches on the edge of this piece that can be used to aid prying.
  • Pry off the bottom piece using the spudger.
  • There are notches on the edge of this piece that can be used to aid prying.
Aggiungi Commento
Remove the sticker overlaying the NEXTEL logo.
  • Remove the sticker overlaying the NEXTEL logo.
Aggiungi Commento
Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
Aggiungi Commento
Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone. Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone. Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
  • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Aggiungi Commento
Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
  • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
Aggiungi Commento
Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone. Do not pull the connector off by the wire.  This could damage or destroy the wire or connector. Do not pull the connector off by the wire.  This could damage or destroy the wire or connector.
  • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
  • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
Aggiungi Commento
Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board. Do not pull the motherboard too far away from the phone with the ribbon cable still connected.  this will damage the cable or the motherboard.
  • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
  • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
Aggiungi Commento
Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone. Be sure to pull straight down to disconnect the ribbon cable properly.  Pulling in another direction may cause damage to the cable or the motherboard.
  • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
  • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
Aggiungi Commento
Using your fingers, carefully lift the rubber keypad from the phone. Note the pegs that stick through the rubber keypad. Lift the keypad carefully so that the pegs do not rip the rubber. Note the pegs that stick through the rubber keypad. Lift the keypad carefully so that the pegs do not rip the rubber.
  • Using your fingers, carefully lift the rubber keypad from the phone.
  • Note the pegs that stick through the rubber keypad. Lift the keypad carefully so that the pegs do not rip the rubber.
Aggiungi Commento
Conclusione
Austin Lake
Membro da: 18/10/2013
501 Reputazione
5 Guide realizzate
Clemson, Team 13-3, Benson Fall 2013 Membro di Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 89
