Introduzione
As this replacement guide works on an internal component of the Xoom Wifi, completion of prior steps to remove external parts is necessary.
There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver. There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
  • There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
Aggiungi Commento
Apply light pressure with hand and slide the back plate till it stops in this position. There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
  • Apply light pressure with hand and slide the back plate till it stops in this position.
  • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
  • As soon as the clips are released the back should slide off.
Aggiungi Commento
Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver. Once both screws are taken out, lift the rest of the backing out of the way. Once both screws are taken out, lift the rest of the backing out of the way.
  • Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver.
  • Once both screws are taken out, lift the rest of the backing out of the way.
Aggiungi Commento
Remove one screw with a T-5 bit. Lift the black casing off of the ports. Remove earphone port from the motherboard.
  • Remove one screw with a T-5 bit.
  • Lift the black casing off of the ports.
  • Remove earphone port from the motherboard.
Aggiungi Commento
Conclusione
William Prins
Membro da: 14/04/2014
545 Reputazione
3 Guide realizzate
Cal Poly, Team 3-39, Maness Spring 2014 Membro di Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 183
