Salta al contenuto principale
Motorola W490 SIM Card Replacement
Cosa ti serve
  1. Motorola W490 SIM Card Replacement, Phone Casing: passo 1, immagine 1 di 2 Motorola W490 SIM Card Replacement, Phone Casing: passo 1, immagine 2 di 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 SIM Card Replacement, Battery: passo 2, immagine 1 di 2 Motorola W490 SIM Card Replacement, Battery: passo 2, immagine 2 di 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 SIM Card Replacement, SIM Card: passo 3, immagine 1 di 3 Motorola W490 SIM Card Replacement, SIM Card: passo 3, immagine 2 di 3 Motorola W490 SIM Card Replacement, SIM Card: passo 3, immagine 3 di 3
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
Conclusione
Will Edwards
Membro da: 10/22/12
61 Reputazione
9 Guide realizzate
Clemson, Team 14-1, Benson Fall 2012 Membro di Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membri
23 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 802
