Parti
Nessuna parte richiesta.
Pick up the cell phone with the back facing towards you. Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
  • Pick up the cell phone with the back facing towards you.
  • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
  • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
Aggiungi Commento
Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery. Set the battery aside.
  • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
  • Set the battery aside.
Aggiungi Commento
After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles. Remove all the screws using the Torx T6 Screwdriver.
  • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
  • Remove all the screws using the Torx T6 Screwdriver.
Aggiungi Commento
Turn over the phone to the front side and open up the phone, displaying the keypad. Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone. Pull and set the glued plastic cover aside.
  • Turn over the phone to the front side and open up the phone, displaying the keypad.
  • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
  • Pull and set the glued plastic cover aside.
  • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
Aggiungi Commento
Under the plastic cover, locate two star-shaped T5 screws. Use the Torx T5 Screwdriver to remove the two screws.
  • Under the plastic cover, locate two star-shaped T5 screws.
  • Use the Torx T5 Screwdriver to remove the two screws.
Aggiungi Commento
Turn over the phone to the back side of phone where the battery was removed. Use hands to remove the unscrewed rear frame of the phone. Set aside the rear metal frame.
  • Turn over the phone to the back side of phone where the battery was removed.
  • Use hands to remove the unscrewed rear frame of the phone.
  • Set aside the rear metal frame.
Aggiungi Commento
Conclusione
Will Edwards
Membro da: 22/10/2012
61 Reputazione
17 Guide realizzate
Clemson, Team 14-1, Benson Fall 2012 Membro di Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membri
23 Guide realizzate
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 351
