Parti
Nessuna parte richiesta.
Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face. Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
  • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
Aggiungi Commento
Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
Aggiungi Commento
Pull the flex cable connection away from the top of the phone. Pull the flex cable connection away from the top of the phone.
  • Pull the flex cable connection away from the top of the phone.
Aggiungi Commento
Pull the camera connection away from the top of the phone. Pull the camera connection away from the top of the phone.
  • Pull the camera connection away from the top of the phone.
Aggiungi Commento
Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone.
  • Pull the upper metal frame away from the phone.
Aggiungi Commento
Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out.
  • Hold the outer phone casing and pull the LCD screen out.
Aggiungi Commento
Conclusione
Will Edwards
Membro da: 22/10/2012
61 Reputazione
17 Guide realizzate
Clemson, Team 14-1, Benson Fall 2012 Membro di Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membri
23 Guide realizzate
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 414
