Open the phone so that the keypad and screen are facing up.
  • Open the phone so that the keypad and screen are facing up.
Aggiungi Commento
Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
  • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
Aggiungi Commento
Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
  • Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
Aggiungi Commento
Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
  • Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
Aggiungi Commento
Conclusione
Will Edwards
Membro da: 22/10/2012
61 Reputazione
17 Guide realizzate
Clemson, Team 14-1, Benson Fall 2012 Membro di Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membri
23 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 322
