Salta al contenuto principale
Motorola W385 Front Casing Replacement
Cosa ti serve
  1. Motorola W385 Front Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Front Casing Replacement: passo 2, immagine 1 di 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Front Casing Replacement, Front Casing: passo 3, immagine 1 di 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Front Casing Replacement: passo 4, immagine 1 di 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Front Casing Replacement: passo 5, immagine 1 di 2 Motorola W385 Front Casing Replacement: passo 5, immagine 2 di 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Front Casing Replacement: passo 6, immagine 1 di 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
Conclusione
Cal Poly, Team 8-50, Regan Winter 2010 Membro di Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,921
