Introduzione
Is the plastic casing cracked or severely scratched? Replace it.
Using your finger, press down on the clip holding the back cover on.
  • Using your finger, press down on the clip holding the back cover on.
Aggiungi Commento
Using the spudger or your finger, gently pull the battery out from the top.
  • Using the spudger or your finger, gently pull the battery out from the top.
Aggiungi Commento
Hold the phone as shown in the photo.
  • Hold the phone as shown in the photo.
Aggiungi Commento
Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center. This might require a little persistence due how the beveled plastic rests on the phone body.
  • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
  • This might require a little persistence due how the beveled plastic rests on the phone body.
  • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
Aggiungi Commento
Remove the two Torx-6 screws under the removed plastic.
  • Remove the two Torx-6 screws under the removed plastic.
Aggiungi Commento
Keeping the phone open, turn it over allowing the battery compartment to be visible.
  • Keeping the phone open, turn it over allowing the battery compartment to be visible.
  • Remove the four Torx-6 screws from the back plastic.
Aggiungi Commento
Hold the phone with the keys facing down and the mini USB charging port visible. Open the rubber flap covering the charging port. Insert the flat end of the spudger just above the charging port.
  • Hold the phone with the keys facing down and the mini USB charging port visible.
  • Open the rubber flap covering the charging port.
  • Insert the flat end of the spudger just above the charging port.
  • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
  • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
Aggiungi Commento
The casing can be easily removed exposing the bottom logic board.
  • The casing can be easily removed exposing the bottom logic board.
Aggiungi Commento
Conclusione
Austin Hobbs
Membro da: 21/01/2010
30 Reputazione
6 Guide realizzate
Cal Poly, Team 8-50, Regan Winter 2010 Membro di Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,249
