Turn off the phone.
  • Turn off the phone.
  • Turn the device over.
  • Remove the battery cover.
Aggiungi Commento
  • Insert thumb in the gap between the button and the battery and pry the battery upwards.
  • Pull the battery out of the phone.
Aggiungi Commento
Insert the new battery.
  • Insert the new battery.
Aggiungi Commento
Four 5 mm screws are visible (circled in red).
  • Four 5 mm screws are visible (circled in red).
  • Using the T6 tool, remove all four 5mm screws and set them aside.
Aggiungi Commento
Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
  • Insert the plastic opening tool between the front and back panels of the lower half of the device.
  • Slide the tool around the entire frame of the device until it has loosened.
  • Remove the back of the device.
Aggiungi Commento
Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon. Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon. Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
  • Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
Aggiungi Commento
Use the plastic opening tool to remove the chip connected by magnetic strip to the screen. Remove circuit board. Remove circuit board.
  • Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
  • Remove circuit board.
Aggiungi Commento
Conclusione
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Membro da: 26/03/2014
401 Reputazione
8 Guide realizzate
Clemson, Team 6-3, Benson Spring 2014 Membro di Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 102
