Salta al contenuto principale
Motorola V710 Logic Board Replacement
Cosa ti serve
  1. Motorola V710 Logic Board Replacement, Battery: passo 1, immagine 1 di 3 Motorola V710 Logic Board Replacement, Battery: passo 1, immagine 2 di 3 Motorola V710 Logic Board Replacement, Battery: passo 1, immagine 3 di 3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Logic Board Replacement: passo 2, immagine 1 di 3 Motorola V710 Logic Board Replacement: passo 2, immagine 2 di 3 Motorola V710 Logic Board Replacement: passo 2, immagine 3 di 3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Logic Board Replacement, Logic Board: passo 3, immagine 1 di 2 Motorola V710 Logic Board Replacement, Logic Board: passo 3, immagine 2 di 2
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Logic Board Replacement: passo 4, immagine 1 di 2 Motorola V710 Logic Board Replacement: passo 4, immagine 2 di 2
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Logic Board Replacement: passo 5, immagine 1 di 3 Motorola V710 Logic Board Replacement: passo 5, immagine 2 di 3 Motorola V710 Logic Board Replacement: passo 5, immagine 3 di 3
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Logic Board Replacement: passo 6, immagine 1 di 2 Motorola V710 Logic Board Replacement: passo 6, immagine 2 di 2
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Logic Board Replacement: passo 7, immagine 1 di 2 Motorola V710 Logic Board Replacement: passo 7, immagine 2 di 2
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Logic Board Replacement: passo 8, immagine 1 di 3 Motorola V710 Logic Board Replacement: passo 8, immagine 2 di 3 Motorola V710 Logic Board Replacement: passo 8, immagine 3 di 3
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Logic Board Replacement: passo 9, immagine 1 di 1
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Logic Board Replacement: passo 10, immagine 1 di 2 Motorola V710 Logic Board Replacement: passo 10, immagine 2 di 2
    • Remove the logic board.
Conclusione
Cal Poly, Team 8-49, Regan Winter 2010 Membro di Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,008
