Introduzione
This is a guide showing how to replace the Motorola V60 speakers.
Parti
Nessuna parte richiesta.
Remove battery cover by pushing down release lever at top of phone while prying off cover. Set cover aside. Set cover aside.
  • Remove battery cover by pushing down release lever at top of phone while prying off cover.
  • Set cover aside.
Aggiungi Commento
Remove battery by grabbing it near the bottom and lifting out. Remove battery by grabbing it near the bottom and lifting out.
  • Remove battery by grabbing it near the bottom and lifting out.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Unscrew four corner screws with T6 screwdriver. Note: Top screws are silver and short while bottom screws are black and longer.
  • Unscrew four corner screws with T6 screwdriver.
    • Note: Top screws are silver and short while bottom screws are black and longer.
Aggiungi Commento
Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting. Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting.
  • Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting.
Aggiungi Commento
Insert spudger between speaker and back chassis and lifting.
  • Insert spudger between speaker and back chassis and lifting.
    • Note: This may take some effort.
Aggiungi Commento
Conclusione
Eric Freeman
Membro da: 26/01/2010
1 Reputazione
13 Guide realizzate
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,442
