Introduzione
This guide shows how to take apart the front casing. This allows access to the front LCD screen.
Parti
Nessuna parte richiesta.
Push in and hold small release latch.
  • Push in and hold small release latch.
  • Hold the latch through step 2.
Aggiungi Commento
While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover.
  • While holding the release latch, use a opening tool to help you slide off the front cover.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the two Philips screws at top of phone with a #1 Philips screwdriver. Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
  • Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
Aggiungi Commento
Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display.
  • Use a opening tool to gently pry off black cover, revealing the internal LCD display.
Aggiungi Commento
Conclusione
Eric Freeman
Membro da: 26/01/2010
1 Reputazione
13 Guide realizzate
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,151
