Salta al contenuto principale
Motorola V60s Button Key Pad Replacement
Cosa ti serve
  1. Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 1 di 3 Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 2 di 3 Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 3 di 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Pad Replacement: passo 2, immagine 1 di 2 Motorola V60s Button Key Pad Replacement: passo 2, immagine 2 di 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Pad Replacement, Logic Board: passo 3, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Logic Board: passo 3, immagine 2 di 2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Pad Replacement: passo 4, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 4, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 4, immagine 3 di 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Pad Replacement: passo 5, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 5, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 5, immagine 3 di 3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Pad Replacement: passo 6, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 6, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 6, immagine 3 di 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Pad Replacement: passo 7, immagine 1 di 2 Motorola V60s Button Key Pad Replacement: passo 7, immagine 2 di 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, immagine 2 di 2
    • Insert spudger under button board and gently lift, set aside.
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, immagine 2 di 2
    • Life button keypad with spudger and set aside.
Conclusione
Eric Freeman
Membro da: 01/26/10
10 Reputazione
7 Guide realizzate
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,013
