Salta al contenuto principale
Motorola V60i Keypad Replacement
Cosa ti serve
  1. Motorola V60i Keypad Replacement, Battery: passo 1, immagine 1 di 2 Motorola V60i Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Keypad Replacement: passo 2, immagine 1 di 2 Motorola V60i Keypad Replacement: passo 2, immagine 2 di 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Keypad Replacement, Back Plate: passo 3, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Keypad Replacement: passo 4, immagine 1 di 2 Motorola V60i Keypad Replacement: passo 4, immagine 2 di 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Keypad Replacement: passo 5, immagine 1 di 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Motorola V60i Keypad Replacement, Motherboard: passo 6, immagine 1 di 1
    • Gently lift logic board from back plate.
  7. Motorola V60i Keypad Replacement: passo 7, immagine 1 di 2 Motorola V60i Keypad Replacement: passo 7, immagine 2 di 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  8. Motorola V60i Keypad Replacement, Keypad Sensor: passo 8, immagine 1 di 2 Motorola V60i Keypad Replacement, Keypad Sensor: passo 8, immagine 2 di 2
    • Once logic board is removed lift the green keypad sensor for the front plate.
  9. Motorola V60i Keypad Replacement, Keypad: passo 9, immagine 1 di 2 Motorola V60i Keypad Replacement, Keypad: passo 9, immagine 2 di 2
    • To replace keypad buttons, lift off white tray containing buttons.
Conclusione
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,860
