Salta al contenuto principale
Motorola V557 Screen Replacement
Cosa ti serve
  1. Motorola V557 Screen Replacement, Faceplate: passo 1, immagine 1 di 3 Motorola V557 Screen Replacement, Faceplate: passo 1, immagine 2 di 3 Motorola V557 Screen Replacement, Faceplate: passo 1, immagine 3 di 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Motorola V557 Screen Replacement: passo 2, immagine 1 di 2 Motorola V557 Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Motorola V557 Screen Replacement: passo 3, immagine 1 di 2 Motorola V557 Screen Replacement: passo 3, immagine 2 di 2
    • Separate the cover from the edges using a plastic opening tool.
  4. Motorola V557 Screen Replacement: passo 4, immagine 1 di 2 Motorola V557 Screen Replacement: passo 4, immagine 2 di 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  5. Motorola V557 Screen Replacement, Camera: passo 5, immagine 1 di 1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  6. Motorola V557 Screen Replacement: passo 6, immagine 1 di 2 Motorola V557 Screen Replacement: passo 6, immagine 2 di 2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  7. Motorola V557 Screen Replacement: passo 7, immagine 1 di 2 Motorola V557 Screen Replacement: passo 7, immagine 2 di 2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  8. Motorola V557 Screen Replacement: passo 8, immagine 1 di 2 Motorola V557 Screen Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  9. Motorola V557 Screen Replacement: passo 9, immagine 1 di 3 Motorola V557 Screen Replacement: passo 9, immagine 2 di 3 Motorola V557 Screen Replacement: passo 9, immagine 3 di 3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  10. Motorola V557 Screen Replacement: passo 10, immagine 1 di 2 Motorola V557 Screen Replacement: passo 10, immagine 2 di 2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  11. Motorola V557 Screen Replacement, Screen: passo 11, immagine 1 di 3 Motorola V557 Screen Replacement, Screen: passo 11, immagine 2 di 3 Motorola V557 Screen Replacement, Screen: passo 11, immagine 3 di 3
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
Conclusione
Cal Poly, Team 7-50, Amido Fall 2010 Membro di Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,749
